It is currently Sat Nov 28, 2026 3:42 pm
 Post subject: GM 3 pin coil?
PostPosted: Mon Sep 30, 2013 5:40 pm
I need to know which pin is the +, - side of the coil? One is suppose to be used as a tach...
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Mon Sep 30, 2013 6:11 pm
I googled "mopar hei conversion" clicked on images and found a bunch of diagrams, they might help.
1964 Valiant - Signet - Convertible - 225 - Push Button 904 - 7.25 - Drum Brakes X4
PostPosted: Tue Oct 01, 2013 8:06 am
I found this pic...
Circuit labeled A -Pink Wire: Power (12 V) Circuit.
Circuit labeled B -White Wire: Tach Signal for the Tachometer in the Instrument Cluster if equipped.
Circuit labeled C -White with Black stripe Wire: Switching Signal Circuit. This wire (circuit) comes from the Ignition Module.
From this site...
http://easyautodiagnostics.com/gm_icm_t ... stic_1.php
So, if i'm going to use the original wiring harness coil 12v + for the start, run source i connect it to (A) on the coil and (B) on the HEI module and connect (C) from the coil to (C) on the HEI module?
The HEI Electronic Ignition Retrofit How-To is a "little confusing" :roll:
http://www.slantsix.org/forum/viewtopic ... 2ad42d5243
If you look at the article it say's:
If you use this combination coil/module assembly, the original coil has three terminal pins:
A) is the coil's primary (+) terminal; gets ignition-on 12v and is connected to module pin "A".
B) is a tachometer signal output. Not used if you don't have a tach.
C) is the coil's primary (-) terminal, goes to module pin "D"
I'm not sure why he's saying module pins "A" and "D"
It looks like he is giving the wiring for the 4 pin HEI module that comes with the coil pack...Is this HEI module usable? Look at the pic
In the article he say's
"The newer style module included with this setup won't work with the Mopar distributor; it's looking for a 0-5 volt square wave, and that's not the kind of signal the Mopar distributor puts out. You can use the early type (4-pin) module—part numbers specified above in the discussion of module selection"
Here's a pic of the setup he's talking about...
PostPosted: Tue Oct 01, 2013 10:07 am
The article is a little confusing, especially on this point, and you found the most complicated wiring diagram for the HEI conversion I have seen yet.
I drew up a wiring diagram of how I believe you need to wire the HEI module and the coil you are using. I left out the relay wiring for simplicity, but I do encourage you to use one.
Sorry about the hand shadows. I had to use my phone to take a picture because my scanner is a PITA to use right now.
PostPosted: Tue Oct 01, 2013 11:36 am
Thanks for the response and drawing the diagram...Reed
That helps confirm what i was thinking! It will be the same setup i have now but with a higher voltage coil...i gapped the plugs to .050 yesterday
I checked the coil it doesn't have any A,B,C letters from what i read the ignition coil connector has the A,B,C lettering.
I'm going to work on adding a relay soon...
PostPosted: Tue Oct 01, 2013 11:48 am
Sounds good. The plug should only go on the coil one way, so use the "A-B-C" on the plug to guide your harness fabrication.
PostPosted: Tue Oct 01, 2013 1:06 pm
does anyone have a part number for the plug that goes to the coil shown?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Tue Oct 01, 2013 6:02 pm
Autozone has the Duralast 1065 for $47.99
Oreilly has the ACDelco PT1795 for $35. 99
You can get the ACDelco for $27.80 off ebay...
I made my own connectors and got the coil pack installed! I'll take some pics tomorrow...
PostPosted: Thu Oct 03, 2013 9:34 am
This is how i mounted the GM coil pack for now...I'm sure it's better to work it out in more of a horizontial position maybe tucked away somewhere or maybe fabricating your own mounting bracket or seperating the two
Since i didn't have a GM coil connector, what i did was take a smaller probably 3/16" spade connector and cut half of one side off with my dremel and crimped it a little bit so it would plug onto the coil pin nice and tight and covered the terminal with heat shrink tubing
I was able to use the orignal coil to distributor connector...i just crimped it so it would fit snug over the gm male coil connector. I had to cut one of the heat sink cooling fins off and grind it smooth to mount the older 4 pin hei module. I figure this will bump the coil output to 40,000-50,000 volts
