It is currently Mon Nov 16, 2026 7:20 pm
PostPosted: Sat Oct 12, 2013 12:40 pm
Is there an O-ring in there that I have to replace? Drain the tranny, replace the seal? Everything seems tight, I don't want to overtorque anything.
thanks all,
BG
PostPosted: Sat Oct 12, 2013 1:37 pm
6 Pack Dart
There should be 2 "O" rings 1 small 1 large and you don't need to drain the transmission, some fluid will leak out but not that much if you have the rear end up.
Richard
 Post subject: thanks....
PostPosted: Fri Oct 18, 2013 8:54 am
Do anyone have the size of these handy? I have a ton of O-rings, but if its a special diameter or thickness...
bg
