transmission leaking where speedo cable goes....
https://slantsix.org/forum/viewtopic.php?t=53571
Author:  '67 Dart 270 [ Sat Oct 12, 2013 12:40 pm ]
Post subject:  transmission leaking where speedo cable goes....
Is there an O-ring in there that I have to replace? Drain the tranny, replace the seal? Everything seems tight, I don't want to overtorque anything.
thanks all,
BG
Author:  Fopar [ Sat Oct 12, 2013 1:37 pm ]
There should be 2 "O" rings 1 small 1 large and you don't need to drain the transmission, some fluid will leak out but not that much if you have the rear end up.
Richard
Author:  '67 Dart 270 [ Fri Oct 18, 2013 8:54 am ]
Post subject:  thanks....
Do anyone have the size of these handy? I have a ton of O-rings, but if its a special diameter or thickness...
bg
