It is currently Sun Jun 21, 2026 9:02 am
 Post subject: Estimated hp?
PostPosted: Tue Oct 15, 2013 7:57 am
Building a 225 and just curious as to what you guys think it will make to the wheels.
1971 225, stock bottom end.
Shaved head .120, engine builder valves, ports cleaned up.
Clifford intake, some kind of 600 4 barrel (undecided)
Distributor recurve, erson high flow am cam, double roller timing chain.
Hooker super comp headers, no exhaust.
Tranny is a 904, regular driveshaft, 8 3/4 with a spool.
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Tue Oct 15, 2013 7:59 am
150 hp
PostPosted: Tue Oct 15, 2013 8:24 am
Car Model: 1962 Dodge Lancer
150 hp
Agree
PostPosted: Tue Oct 15, 2013 8:47 am
PostPosted: Tue Oct 15, 2013 12:52 pm
It should make some more power than stock, but very little low end torque (driveability). Id say the 600cfm is unnecessarily large, try a holley 390.
PostPosted: Tue Oct 15, 2013 1:45 pm
This is the unknown? What specs.
A 600 Edelbrock may be just fine. A 500 may be better. A Holley if you enjoy fiddleling with it all the time.
I have run 600's on everything from bone stock engines to my race car and they ran just fine. Your results may vary! :lol:
Rick
 Post subject: Lol...
PostPosted: Tue Oct 15, 2013 3:34 pm
If you can get the SCR to 11:1 on that cam, you should have about 180hp to play with (and maybe a bit more). I was able to drop another 1/2 second off my time going from the holley 390 to the holley 600 because the throttle plate relationship compared between the small bore carb and large bore carb was different. Most mid-range performance slants will want 450 cfm for max throttle the 390 is a bit short and the 450 Holley is not the best, 600 cfm holleys with the brown spring in the secondaries will do the job (and you can get a good rebuilder on craigslist for $50-75. The 500cfm Edelbrock would be another good choice as well.
(Hi-po engines like this tend to idle better with the bigger carb and tune the idle screws easier than the little carb...i.e. better to be 1/2 turn out than 3.25 turns out)
Erson AM high flow cam is 286/296 .551 lift, was ground during the Erson group buy.
