It is currently Mon Nov 16, 2026 6:07 am
 Post subject: What gear do i have?
PostPosted: Sat Oct 19, 2013 10:13 pm
Car Model: 62 Valiant and 62 Lancer, both Swiss Made
I've bought a 68 Valiant, 4 door, in a real bad condition. The car was for many years in a wreckyard, without front window. But the engine and gear are in a good condition, i was able to start the engine just by adding some gas in the carb.
The car is fitted with a manual four speed gear, floor shifter. The car was produced in Switzerland, so i think the four speed is made for swiss or european market only these years.
Any ideas what gear type thi s could be?
62 Valiant
62 Lancer
PostPosted: Sun Oct 20, 2013 7:11 am
From sticky at top of Transmission Page:
http://www.slantsix.org/forum/viewtopic.php?t=36418
PostPosted: Sun Oct 20, 2013 7:55 am
wjajr, thank you for the link.
Sorry about my english, but his was not my question. I wonder what type of gearbox this is. Maybe A-833?
62 Valiant
62 Lancer
PostPosted: Sun Oct 20, 2013 12:45 pm
Oh! Sorry about that.
Take a look here for transmission bell housing numbers
[2806718] [G/RG A-833] [1967-1972] [export only] --- if this matches, gear ratios can be found on site listed below
and book mark this site for more decoding of Chrysler stuff.
 Post subject: It's most likely....
PostPosted: Sun Oct 20, 2013 1:05 pm
You most likely have the A-833 if it a stock floor shift 4spd Valiant.
If not original you'll need to check the marks to see if its the direct
version or the later overdrive version.
Although there are some industrious people that could make something
else fit, but it's a lot of work...
PostPosted: Mon Oct 21, 2013 8:51 am
Many thanks!
Number is 2806 720, and it is the original gearbox.
Maybe because the car was made in the plant here in Switzerland, the number is not in the mymopar.com listing.
62 Valiant
62 Lancer
 Post subject: Re: It's most likely....
PostPosted: Mon Oct 21, 2013 10:06 am
Car Model: 1971 Scamp
Didn't the Brazilian/Mexican made A bodies get some kind of Borg Warner trans? Maybe its a similar deal since it was made in Switzerland?
