It is currently Thu Jul 16, 2026 12:21 am
PostPosted: Mon Oct 28, 2013 5:48 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Any suggestions on how to install a mech. oil pressure and mech. oil temp gauge?
Could I run a t fitting type setup? Or is this a bad idea??
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Mon Oct 28, 2013 6:46 pm
6 Pack Dart
The "T" will give you the Idiot light so if you don't look at the gauge should the oil pressure drop unexpectedly. The idiot light is a lot easier to notice if it should come on.
Richard
 Post subject: Mock it up first...
PostPosted: Mon Oct 28, 2013 7:01 pm
Make sure to mock it up, I had to mock up 3 oil pumps to find one that was threaded straight for the fittings to work (the first one was so far off I installed the fittings, then installed the oil pump and the angle cracked the bronze 'T' when I started to snug up the pump to the block (luckily it was a new build and on a stand). OEM pumps seem to be better/straight.
