Installing mech.oil temp and mech.oil pressure gauge?
https://slantsix.org/forum/viewtopic.php?t=53715
Author:  NCDemon1971 [ Mon Oct 28, 2013 5:48 pm ]
Post subject:  Installing mech.oil temp and mech.oil pressure gauge?
Any suggestions on how to install a mech. oil pressure and mech. oil temp gauge?
Could I run a t fitting type setup? Or is this a bad idea??
Author:  Fopar [ Mon Oct 28, 2013 6:46 pm ]
The "T" will give you the Idiot light so if you don't look at the gauge should the oil pressure drop unexpectedly. The idiot light is a lot easier to notice if it should come on.
Richard
Author:  DusterIdiot [ Mon Oct 28, 2013 7:01 pm ]
Post subject:  Mock it up first...
Make sure to mock it up, I had to mock up 3 oil pumps to find one that was threaded straight for the fittings to work (the first one was so far off I installed the fittings, then installed the oil pump and the angle cracked the bronze 'T' when I started to snug up the pump to the block (luckily it was a new build and on a stand). OEM pumps seem to be better/straight.
