It is currently Tue Feb 18, 2025 5:21 pm
PostPosted: Wed Oct 30, 2013 1:16 pm
piecing it together. would like to use the original throttle rod type linkage (i have it but missing the rubber insulator that goes into carb lever. is this obtainable or substitute what? only carb i have to use is early Holley 12R-3100 or maybe says 3106? question is what is best way to adapt the carb lever so i can insert that throttle rod? or should i look for carter 1bbl? i lookin in search area but didn't find anything.
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
PostPosted: Wed Oct 30, 2013 3:16 pm
I cut a piece of 1/4'' fuel hose and added a hose clamp to hold it on the inside of the U (C?)shaped bracket of the carb(for lack of a better way of describtion) Not factory but worked.
PostPosted: Wed Oct 30, 2013 9:09 pm
Those little rubber gadgets are available.
http://www.ebay.com/itm/1960-61-62-63-6 ... ce&vxp=mtr
BC
Users browsing this forum: eric22t, Google [Bot], Semrush [Bot] and 9 guests
