Slant Six Forum https://slantsix.org/forum/ |
65 dart slant carb? throtttle rod insulator? https://slantsix.org/forum/viewtopic.php?t=53723 |
Author: | barbee6043 [ Wed Oct 30, 2013 1:16 pm ] |
Post subject: | 65 dart slant carb? throtttle rod insulator? |
piecing it together. would like to use the original throttle rod type linkage (i have it but missing the rubber insulator that goes into carb lever. is this obtainable or substitute what? only carb i have to use is early Holley 12R-3100 or maybe says 3106? question is what is best way to adapt the carb lever so i can insert that throttle rod? or should i look for carter 1bbl? i lookin in search area but didn't find anything. |
Author: | Romeo Furio [ Wed Oct 30, 2013 3:16 pm ] |
Post subject: | |
I cut a piece of 1/4'' fuel hose and added a hose clamp to hold it on the inside of the U (C?)shaped bracket of the carb(for lack of a better way of describtion) Not factory but worked. |
Author: | 64ragtop [ Wed Oct 30, 2013 9:09 pm ] |
Post subject: | |
Those little rubber gadgets are available. http://www.ebay.com/itm/1960-61-62-63-6 ... ce&vxp=mtr BC |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
