It is currently Fri Nov 27, 2026 12:49 am
 Post subject: turbo oil feed
PostPosted: Wed Oct 30, 2013 8:44 pm
would there be any problem using brake line as an oil feed? my turbo has a restriction in it smaller than the opening in the brake line so i dont think flow should be a problem. what is everyone else using?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Thu Oct 31, 2013 5:56 am
No problem with that. I used an AN-4 line because it was easy to route and connect
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Oct 31, 2013 11:03 am
I just put a "tee" in at the filter fitting, measured the distance from the oil filter, back to the firewall, across to the driver's side inner-fender panel and went forward to the turbo oil inlet. Then, I went to an auto-supply store and got a pre-cut, pre-flared piece of brake hose that length and bolted it on... Took all of 20-minutes...
A piece of cake~
Good luck! Smile
Bill, in Conway, Arkansas
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Thu Oct 31, 2013 12:56 pm
Car Model: 1965 Barracuda 'S' auto
Yup, same as Bill but i went motor route: T at sender, up to valve cover rail forward using that bendable anchor thingy, around front of valve cover to turbo. Use a tube bender and it looks like it belonged their. I went cheap and used an old trans cooler line, cut end and used a short piece of hose to connect to turbo inlet. You can press in a carb jet into the rubber hose as a restrictor if turbo doesnt have one. something like .75-1 lpm.
I didn' t buy it, I built it.....
PostPosted: Thu Oct 31, 2013 2:04 pm
sweet. thanks for the replies. i have about 30 inches of 4an braided line that i was gonna use and use the brake line to make up the difference.
