It is currently Sun Nov 29, 2026 2:51 pm
 Post subject: Crankshaft Fillet
PostPosted: Mon Dec 02, 2013 1:41 pm
Hi all,
I was cleaning my crankshaft ready to get it ground and i noticed that the rod fillets seem "rough/crazed", one of the fillets even has a jagged saw toothed edge on the journal side as if it had some rough machining done (the first two photos are of the worst fillet).
I don't know if this is ok or whether this crank is scrap? Any input would be appreciated.
PostPosted: Mon Dec 02, 2013 3:16 pm
Car Model: 1964 Valiant V200
That is normal. The filets are rolled on the crank after forging and before grinding. It is not a precision process (or at least it wasn't on these cranks).
PostPosted: Mon Dec 02, 2013 3:53 pm
Car Model: 64 Valiant
That is common with Chrysler, Dodge and Plymouth cranks. They choose to undercut the filet instead of having it ground and blended with the journals bearing surface.
PostPosted: Tue Dec 03, 2013 12:56 pm
Great thanks :)
