| front sway bar https://slantsix.org/forum/viewtopic.php?t=54072 |
Page 1 of 2 |
| Author: | '67 Dart 270 [ Sun Dec 15, 2013 7:55 pm ] |
| Post subject: | front sway bar |
I have LCA's from 74 dart with factory sway bar tabs and I (now) have an upper sway bar (same vintage), pins and brackets. I have a '67 dart; has anyone mounted the new mopar sway bar to the '67 K frame? Anyone have pics? Can I use the factory mounts from the new bar or do I need to fabricate something special? thanks all, BG |
| Author: | '67 Dart 270 [ Sun Dec 15, 2013 9:07 pm ] |
| Post subject: | new sway bar, older K frame |
The newer K frame has a passage through for the sway bar, do I need the new K frame as well or is there a way to cut/make passages in the existing older K frame? If I switch to a newer K frame, what else has to be swapped? I have the LCAs will get UCAs for disc brake conversion anyhow. bg |
| Author: | Reed [ Sun Dec 15, 2013 10:53 pm ] |
At a minimum you need the newer k frame and newer lower control arms. |
| Author: | '67 Dart 270 [ Mon Dec 16, 2013 9:19 am ] |
| Post subject: | sway bar... |
I have the new LCA's, I'm refurbishing now. Can I swap out the K frame without pulling the engine? I'll be changing the LCA's, UCA's for the disk brake conversion, if I could swap K frames (idler arm, whatever else I need) without pulling the engine I'd be a happy camper... On the other hand I've seen other sway bars that are mounted to the existing older K frames; not sure if that was with the newer LCA tab location or not, but I assume so, since Hotchkiss, e.g., sells those weld on tabs for older cars and the instructions say to weld where the newer LCA's have the tab... I was telling Rob, I'm half tempted to cut a path in my old K-frame and weld in a 2 x 4" square channel (say 1/4" thick steel) with a couple supports across the open side - make my own K frame custom for the newer sway bar...might actually be easier than swapping out for the newer one. OK, if I do this crazy project I'll be sure to post pics... |
| Author: | Reed [ Mon Dec 16, 2013 9:22 am ] |
| Post subject: | Re: sway bar... |
Quote: Can I swap out the K frame without pulling the engine?
I suppose you could if you built some kind of gantry to support the engine while you dropped the K-frame.Quote: On the other hand I've seen other sway bars that are mounted to the existing older K frames; not sure if that was with the newer LCA tab location or not, but I assume so, since Hotchkiss, e.g., sells those weld on tabs for older cars and the instructions say to weld where the newer LCA's have the tab…
The 67-72 factory sway bar mounted in front of and below the older K-frame. Very exposed. The sway bar tab location on the lower control arms was also different than the 73-73 tab location.Quote: I was telling Rob, I'm half tempted to cut a path in my old K-frame and weld in a 2 x 4" square channel (say 1/4" thick steel) with a couple supports across the open side - make my own K frame custom for the newer sway bar...might actually be easier than swapping out for the newer one. OK, if I do this crazy project I'll be sure to post pics...
| Author: | '67 Dart 270 [ Mon Dec 16, 2013 10:26 am ] |
I could support the engine somehow, if at least with a cherry picker. I could put some support under it until I was ready to rebolt the new K frame. Rob says I may also need a new idler arm, pitman arm and steering link and spool motor mounts. Can somebody send me pics of each of these..what are the spool motor mounts, how is the new K frame different there? The pitman arm is the one between the steering box and the steering link, right? Which is the idler arm? Anybody have a newer K frame and assorted items for sale? Bg |
| Author: | '67 Dart 270 [ Mon Dec 16, 2013 10:44 am ] |
| Post subject: | another idea... |
Yes, I looked at the Hotchkiss setup, it looks awfully low to the ground... but here's one on the boards, on a '67 that looks pretty good. http://slantsix.org/forum/viewtopic.php ... ar+k+frame bg |
| Author: | '67 Dart 270 [ Tue Dec 17, 2013 12:40 pm ] |
| Post subject: | front sway bar... |
OK, I did some research and what I need is a sway bar that mounts to the 73-76 factory sway bar tabs on the LCA's, like a Hotchkiss, BUT where the bar is configured over the K frame support in the front of the K frame. The link below shows one over the K frame front support on a '67, but the sway bar is mounted using the lower shock bolt in this case. The factory tabs on the 73-76 lower LCA, and this sway bar pictured, would interfere with the strut at the LCA. http://www.forabodiesonly.com/mopar/sho ... p?t=124741 Is there an aftermarket front sway bar that works with the 73-76 LCA sway bar tab and mounts to a '67 K frame with the bar over the K frame front support? If not, I'm very tempted to do surgery on my '67 K frame (in place) to create a channel for the factory 73-76 sway bar (or aftermarket sway bar for '73-76). I kind of want to try this just to see if I can do it... K frame probably needs some rewelding anyhow 'cause the spots come loose over time. bg |
| Author: | '67 Dart 270 [ Tue Dec 17, 2013 12:48 pm ] |
| Post subject: | or.... |
Duh...I could just use the lower shock bolt and forget that I have the factory tabs on my 73-76 LCA's......if the L brackets for the sway bar that bolt to the K frame are flimsy (I think someone said) I can fabricate super heavy duty ones myself. Thoughts anyone? |
| Author: | Reed [ Tue Dec 17, 2013 1:21 pm ] |
Quote: I say just swap in a newer K-frame. You will get the better spool mounts that way too.
| Author: | '67 Dart 270 [ Tue Dec 17, 2013 2:03 pm ] |
| Post subject: | newer k frame... |
That's high on my list, because I like how the later sway bar passes through the K frame, seems like a much better more thought out arrangement. |
| Author: | wjajr [ Wed Dec 18, 2013 4:32 am ] |
This is thebracket I used to attach sway bar to front of K Member when replacing junk Addco universal angle iron mount. It is identical to factory mount, and bolts up using factory holes. Like I said I had to do a little egging of larger bar's bushing retainer bolt holes to mate it this bracket. The angle iron pieces Addco supplied were plenty strong enough, the problem was the K Member where only two bolts attached the angle iron to it. Using Addco's lower shock bolt angle attachment method is strong enough if a grade 8 bolt is used, and torqued correctly. |
| Author: | Slanteast [ Wed Dec 18, 2013 5:19 am ] |
Very clean engine compartment, nice work. What brand of aluminum fan did you use? I used 2 x 2.5 Hookers into a Y and then into one 3'' in and out muffler with a TTI 3'' tail pipe. It sounds really good. Excellent details. Derek |
| Author: | 2 Darts [ Tue Jan 07, 2014 9:13 am ] |
The shock bolt mount for the anti-sway bar link has two problems: 1. The Addco tab is flimsy and unstable. In hard cornering it tends to bend and/or rotate around the shock bolt. The latter serves to loosen the nut. 2. The Addco tab requires an anti-sway bar that is 3-4" longer than the factory bar. There isn't a lot of room between a 73 & > caliper and the anti-sway bar to begin with. Collision between the bar and caliper is likely to result yielding damage to the bar and reduced turning radius. |
| Author: | DusterIdiot [ Tue Jan 07, 2014 8:53 pm ] |
| Post subject: | That's the reason for the side to side swap... |
Quote: There isn't a lot of room between a 73 & > caliper and the anti-sway bar to begin with. Collision between the bar and caliper is likely to result yielding damage to the bar and reduced turning radius.
People who experience this in pre-72 cars typically swap their spindles side to side so the caliper is on the opposite side of the disc from the position of the sway bar...If you did a drum brake to disc swap on a '73m, it sounds like it was installed with the spindles swapped when installed?See this pic/article: http://www.moparmusclemagazine.com/tech ... to_20.html -D.Idiot |
| Page 1 of 2 | All times are UTC-07:00 |
