It is currently Thu Nov 12, 2026 9:22 am
PostPosted: Tue Dec 24, 2013 9:17 am
Red text is a link. left click on the text, and you will go to the information described.
TECHNICAL ARTICLES
4 Speed Transmissions (by Doug Dutra)
Clutch Overview
Band Adjustment
Slant 6 10" Performance Clutch Install 3-16-12
Pre-'64 auto trans filter retrofit
833 OD mainshaft fix tutorial
904 shift point adjust
904 TRANS:
What V8 guts swap into a slant case?
Can you ID this 904 LU?
No kick downshaft on this LU 904
Hooking up the 904 to my electronic speedo?
How to disable the lockup feature on a lockup A-904 or A-727
Recommendation for floor shifter for 904
Repair of ring gear on 904
This is WHY I hate lock-up transmissions
Disection of a 1978 S/6 lock-up 904 trans
727 TRANS
904 to a 727
Trans swap (to a 727 from 904)
kickdown for 727
727 auto won't bolt back onto 225 /6
Adventures in kickdown (fabbing kickdown)
Confused...904 vs. 727 spline
MOPAR MANUAL TRANS (833, A-903, etc)
T5 TRANS
Brief t-5 install instructions.
Found a T-5 now off to the planning department
T-5 Swap Pieces?
T-5 Behind a Slant
Photo of T5 adapter and install
Doing the T-5 swap need advice
T5 Slanters Needed
T-5 from a 2000 V6 Mustang
Another 5 speed question
What 5 speed to a Slant
interesting trans swap option(Sandy in BC brief description of install)
What 5 speed would you use?
There will be more to add just be patient.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
 Post subject: Er...
PostPosted: Tue Dec 24, 2013 11:03 am
You might change the heading on the "833" as we also get a fair amount of questions regarding the 3 speed transmissions as well (A-745,A-903, A-250, A-230)... hence the 4 speed article also has a small section for the 3 speeds.
just a suggestion
:wink:
PostPosted: Tue Dec 24, 2013 11:14 am
Site Admin
Take a look at the main FAQ, and let me know if this is the way it should read.
CJ
