It is currently Sat Nov 21, 2026 11:15 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Sat Dec 04, 2010 10:27 pm
Re: title... I've owned multiple slant sixes, and all of them have leaked oil, so I was wondering if anyone's found a gasket for the rocker cover that does not leak? I need to check the valve clearances on the rig I just bought and so wondered what gasket to get BEFORE I pull the cover :)
PostPosted: Sat Dec 04, 2010 10:46 pm
Once the valve cover is flat, cork works fine until it's over torqued.
I run the rubberized gaskets, so I can retorque them several times.
Available at most major auto parts stores. I got my last one at Carquest.
I use a small ball pean hammer and a block of wood to straighten out my valve covers. So far, I haven't had one come into my ownership that hadn't been overtorqued and dimpled around the bolts. :roll:
2¢
PostPosted: Sat Dec 04, 2010 11:10 pm
I'm also in Oregon, where might you be? I'm on the "dry side" ( eastern ) of the state...
PostPosted: Sat Dec 04, 2010 11:14 pm
I use the rubber ones so I can reuse them.
Also smear some white grease on both sides so it doesn't stick..........
PostPosted: Sat Dec 04, 2010 11:19 pm
6 Pack Dart
CJ is just off I-5 below Albany, I am in Eugene
Richard
PostPosted: Sat Dec 04, 2010 11:33 pm
LOL, wet siders :) Too bad yer so far away. That's a 5 to 6 hour drive for me, assuming no bad traffic through hel... err, Portland area.
Thanks for the input guys. I'll check and see what I can find that's rubber. Would lubriplate work as good grease for prevention of sticking?
PostPosted: Sun Dec 05, 2010 5:17 am
As ed said - - He that rhymes..
I use the Fel-Pro rubber ones with my dart (and other slants) which has a spray bar in the top of the valve cover so there is tons of oil coming down in there.. no problems or leaks and they are re-useable... Just dont overtighten.
PostPosted: Sun Dec 05, 2010 9:45 am
I also use a Fel-Pro rubber gasket, and never use a wrench to torque it down, only a nut driver. I have found that ones hand can feel where the sweet spot between leaks & no leaks is without over tightening. I also have cemented the gasket to the valve cover so it won’t get out of shape from being stretched during cover removal when half it stays with the head, and the rest sticks to the cover.
That gasket has been on and off the head countless times and still seals with no oil dribbles.
Bill
PostPosted: Mon Dec 06, 2010 6:14 am
Im with Bill=WJAR +1
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jan 13, 2014 12:35 am
First post so sorry in advance. I am looking at parts to complete my next service and this thread has been very helpful so thanks all.
I have found 2 felpro products which i think are the match for my 1967 VC Valiant Regal.
#1 VS 12608
http://fme-cat.com/overlays/part-detail ... tOkdftj6So
or
#2 VS 12608 R
I am pretty sure that it is the #1 but was wondering if anyone had any info on what the R is?
Thanks in advance also.
NickD
Everyday Driver
1967 Valiant VC Regal (work in progress)
PostPosted: Mon Jan 13, 2014 12:50 am
Nick, R is for rubber. So that's the one that is being recommended in most of the comments above.
PostPosted: Mon Jan 13, 2014 4:02 am
Personally, I like the cork ones better. I use weather strip cement to hold the gasket to the valve cover, and a wipe of grease, on the head side. Do not over tighten and make sure the flange is straight, and flat.
I have never used them, but I hear good things about these gaskets.
http://realgaskets.com/
http://realgaskets.com/files/automobile.htm
MVC-3
PostPosted: Mon Jan 13, 2014 7:30 am
Real-Gaskets! They are worth the price. I had their valve cover gaskets on my motorcycle for over 20 years!(Never Leaked)
1964 Dart GT
PostPosted: Mon Jan 13, 2014 9:07 am
realgaskets.com on the race car.
Will
PostPosted: Mon Jan 13, 2014 9:35 am
Car Model: 1971 Scamp
MVC-3
Never seen these, I think I will try one out. Thanks for the link!
