It is currently Sat Dec 27, 2025 10:44 pm
PostPosted: Tue Feb 11, 2014 3:43 pm
http://s1270.photobucket.com/albums/jj602/Szabo99/
Has anybody has any luck with this set up getting kickdown linkage to work right. I made my own modified one for my old carter 2bbl and worked fine. But cant seem to get it to work right with the new holly. Any suggestions Pics on link. I know ther is an aftermarket available but looking for info on the right direction.
74 Dart Swinger, supersixed.
PostPosted: Tue Feb 11, 2014 4:07 pm
Most folks go with a Lokar cable and Holley carb brackets.
 Post subject: x2
PostPosted: Tue Feb 11, 2014 4:21 pm
Yep, that's the easiest way to go.
PostPosted: Tue Feb 11, 2014 7:19 pm
I kind of figured that was the route I would have to take, but wanted to see if any of you guys had any tricks or tips you might share on making one. I have been searching threads on here and other sites but not much luck so far on making one. Thanks for the feedback though, always appreciated.
PostPosted: Fri Feb 14, 2014 11:43 pm
Well ordered the lokar kit today, the bep looked better but double the cost..so went with lokar hopefully it will do the job..
