It is currently Mon Nov 23, 2026 9:21 am
PostPosted: Sat Feb 15, 2014 8:40 am
Question for the engine builders. What are you using to install pistons into the block? Old school band clamp, plier style, tapered? Sources? Thanks
PostPosted: Sat Feb 15, 2014 8:47 am
Site Admin
Ring compressor band clamp is what I use.
CJ
PostPosted: Sat Feb 15, 2014 9:27 am
I like the tapered aluminum type the best. You can get one that is about 3.5 inches but adjustable over a range that covers most slant 6 bore sizes. Powerhouse or any place that sells engine building tools should have one.
PostPosted: Sat Feb 15, 2014 9:40 am
Band style. If it was good enough for my Dad it's good enough for me. :lol:
Actually a taper style is easiest.
 Post subject: Yep...
PostPosted: Sat Feb 15, 2014 10:02 am
I actually use my grandfather's version he left me...funny how it was used to rebuild big blocks, now is only doing small bore tilt blocks... :lol:
 Post subject: Summit
PostPosted: Sat Feb 15, 2014 10:52 am
Here is one from Summit I am ordering. 3.4" - 3.550 should cover all of our engines.
http://www.summitracing.com/parts/sme-90a3400/overview/
PostPosted: Sat Feb 15, 2014 4:40 pm
That's nice. They really do speed up assembly.
 Post subject: Tools
PostPosted: Sat Feb 15, 2014 7:20 pm
Thanks Guys. For years I have used the band type, but I am getting too old to fight it anymore. I used a tapered one on a couple of 340's I built and it worked good. I need one now for this little motor on the stand. Rick I saw that one at summit also and it looks good and cheap enough. Anyone used the snap-on plier type?
PostPosted: Sun Feb 16, 2014 6:46 am
I have the plier type.They have a "top" and taper.Loaned it out to a novice and he used it up side down and broke almost all the rings before asking for help. :oops:
