It is currently Mon Nov 23, 2026 10:22 am
 Post subject: carter carb
PostPosted: Mon Feb 17, 2014 6:28 pm
Need to rebuild the carb on my 1963 slant 6.
It is a single barrel and missing the ID tag.
How do I attach or insert a photo of the carb??
Any recommendations for a rebuild shop or replacement?
PostPosted: Mon Feb 17, 2014 7:16 pm
Welcome aboard Scuba1x.
Look here for posting links, photos etc. Click on red text.
You should be able to rebuild your carburetor with a few simple tools. Once you know what it is, get a rebuild kit and have at it. These kits are just new gaskets, and a few parts that wear such as needle valves, and accelerator pump diaphragm. Not much to a one barrel, and plenty of help around here if you get stuck.
Try to pick up a Factory Repair Manual for your car's year and model, they are on the web in book and disk form, and prices very so shop around.
PostPosted: Tue Feb 18, 2014 5:35 pm
[img]http://www.flickr.com/photos/118045173@N05/
Here is the photo of the carb
Anyone know the model of this carb?? (id tag is missing)
Thanks![/img]
PostPosted: Tue Feb 18, 2014 7:38 pm
Looks like a standard Carter BBS. Yours has the external choke pull off so it's not a factory 63, so play it safe and get a kit for a 65 although they're probably the same kit anyway.
I just looked up on RockAuto, anyone know they not only stopped carrying carbs for the slant, but the rebuilds as well?? Our suppliers are drying up. :(
PostPosted: Tue Feb 18, 2014 7:42 pm
Found a kit on ebay:
http://www.ebay.com/itm/61-72-Dodge-Ply ... 61&vxp=mtr
PostPosted: Tue Feb 18, 2014 8:36 pm
Thanks!
I just ordered the rebuild kit from the link provided! :D
