It is currently Thu May 07, 2026 7:21 am
PostPosted: Sat Feb 22, 2014 9:47 pm
hey all of our Aussie valiants had borg warner diffs, & there still used today by holden & ford & some skylines use them also. do you guys have them & call em something else???? or is it chalk & cheese.
PostPosted: Sat Feb 22, 2014 9:57 pm
Hey fellow Aussie! Pretty sure the Borg Warner diff is an Australian specific part,like the email alternators,bosch dizzys and email carter carbs......all were part of making up the Australian content of our Vals. Good to see another down under member here.....just read your intro post,if you are ever looking for any bits give me a holler,I've got a 2 bbl setup for a VF as well as a few decent engine parts if you ever get stuck. Cheers!
PostPosted: Sun Feb 23, 2014 7:59 am
No, but I wish we did. They seem to hold up better than the 7.25" Chrysler axle.
PostPosted: Sat Mar 01, 2014 6:46 am
i'm going to try a rebuild using the 25 spline axles & find a good lsd center for now. i have been told to use studs for the bearing caps & also brace the inspection cover & weld 2 nuts to the bracing & run bolts through the cover & sit snug onto the bearing caps to stop cap walk. ??? old mate said he'll do it for me , so if he's offering he can go for it.
PostPosted: Sat Mar 08, 2014 8:33 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
We had some 7 1/4" rear axles here too, up until some time in '66 or '67.
I have 2 VC Valiants here, 1 has the Spicer, the other the BW.
Richard (aka Fingers)
PostPosted: Sat Mar 08, 2014 9:41 pm
Site Admin
Just did a Quick-Fuel Aluminum Billet Cover with cap Support studs on a 12 bolt. Wonder if you can get something similar.
Chalk and Cheese? Sounds like apples and oranges.
CJ
