It is currently Sat Nov 28, 2026 8:09 am
PostPosted: Tue Mar 04, 2014 9:04 am
87' D100 truck can you disconnect the harness at the bulk head? I would like to remove the entire harness from the cab and engine bay...
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Tue Mar 04, 2014 10:49 am
Yes you can.
Should be a screw in the middle of the connector takes a 3/8" or 5/16" socket can't remember which.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Wed Mar 05, 2014 9:19 am
I've loosened that screw...will the harness pull apart? Is it plugged in together right there at the bulk head?
PostPosted: Wed Mar 05, 2014 9:22 am
Yes, just wiggle and pull.
Mattelderca
PostPosted: Wed Mar 05, 2014 10:19 am
Its gonna take some wiggling, pulling and probably a few curse words... Chances are it hasnt been apart in many, many years so dont expect it to release very easy! Theres going to be corrosion on the terminals, corrosion between the plastic bulk-head connector, and maybe even some heated/melted plastic on the connector, all of wich is going to hold it together pretty tight :D
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
PostPosted: Wed Mar 05, 2014 10:42 am
I redid my wire harness in 2012 i did not encounter any corrosion on the terminals.
However it is a 50 pin terminal it will not just fall off it will need a little wiggling and some pulling as said above.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Wed Mar 05, 2014 11:00 am
Thanks for the responses...it will be tomorrow before i can give it a try! It's nice to know how something works before you try and take it apart 8)
PostPosted: Fri Mar 07, 2014 9:42 am
I seperated the wiring harness yesterday! I pulled from the engine bay side it looks like the cab side of the harness is held in by two plastic clips on the sides that you depress to remove from the cab frame...
Fortunely the wires were not corrodid so it wasn't too hard to seperate! Just wanted to add for anyone who does this in the future to try pulling from the engine bay side first after loosing the holding screw
PostPosted: Fri Mar 07, 2014 11:51 am
Spray those ends with some "CorrosionX" while it's apart. The Coast Guard swears by this stuff......so do I. A very good product. :D
PostPosted: Mon Mar 24, 2014 9:41 pm
Silly question, maybe (not my first and probably not my last) but why remove the engine and cab harnesses??
BC
PostPosted: Wed Mar 26, 2014 12:49 pm
To recondition the connections. They corrode and burn over time....especially after 40 years!~
and or to repaint the engine bay.
PostPosted: Wed Mar 26, 2014 4:52 pm
Yeah and the insulation on the wire has a tendency to get brittle and fall off after 40 yrs.
Which is why I had to do my harness couple yrs ago.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
