It is currently Sat May 02, 2026 4:40 am
 Post subject: Have you heard of this
PostPosted: Tue Apr 15, 2003 12:53 pm
Have 63 GT with 904 and no trans kickdown, per DD's :?: advice checked to find evidence of it having been removed also spoke with orginal owner and he stated it never had one. A check of the trans bears this out, no provisions for linkage found and the opening in housing covered by a bolted on plate. What interinal modifications would have been done as all 904 require slight line pressure to operated properly yet I have no driveability issues and trans has never been out of the car.
PostPosted: Tue Apr 15, 2003 4:14 pm
Wow, no throttle pressure lever comming out of the tranny. :shock:
To make this work the main line pressure and govenor pressure have to be used to control the shifts and hold the clutches / bands.
That works but the trans will be kinda stupid and always shift the same way no matter what the load is.
PostPosted: Tue Apr 15, 2003 7:16 pm
Thats weird :shock:
I say drive it like a stick :D
