It is currently Sat Nov 21, 2026 7:03 am
PostPosted: Fri Mar 28, 2014 2:35 pm
I have a 71 dart 225 with a 904 transmission. I am installing a 8 3/4 rear with 3.55 gears. How and which speedo gear do I replace it with? My tires are 215 75 15 if that helps.
 Post subject: Fun...
PostPosted: Wed Apr 02, 2014 5:35 pm
that combination puts the needed gear close to a 33.6...so you have a choice of a 33 or 34 tooth gear (whichever is easiest to find), and adjusting your eyes to make up for the speedo being slightly fast or slow depending on which you get.
