It is currently Sat Nov 28, 2026 8:07 am
 Post subject: wiring in an ammeter
PostPosted: Sat Apr 05, 2014 10:11 am
I am wiring up my drag car from scratch. no stock harness etc.
I am wiring in an ammeter.
where do the 2 terminals of the gauge get wired to t get an accurate reading?
PostPosted: Sat Apr 05, 2014 10:15 am
Negative side to battery + and the other side to the rest of the electrical system including the alternator. This assumes you want to know the power going into and out of the battery the way most ammeters are wired.
PostPosted: Sat Apr 05, 2014 10:46 am
Greg,
Think of amp gage as a direction of electron flow indicator. Install it such that when juice if flowing from alternator to battery the gage reads +, and when all flow is from battery it reads minus. The stock method is black wire from alternator passes through fire wall to gage, from here it splits off to loads both fused and not and back out to the battery with a red wire. So when alternator is contributing more flow of electrons that is to say charging battery, gage reads +, and when battery is contributing more electrons to the harness compared to alternator out put the gage reads negative.
Just look at a stock wire diagram and see how the gage is located between load (stuff being powered) battery and alternator. Cross off any load in diagram you do not have, and that’s one way to accomplish your mission.
oops... I got tasked to perform a "Honey Do" mid post, and Josh popped in with a clearer explanation while in the trenches.
Bill
PostPosted: Sun Apr 06, 2014 5:13 pm
just asking,, any specific reason for going with an ammeter and not a voltmeter?
A voltmeter tells you the power available to run the ignition, fuel pumps,,
PostPosted: Sun May 04, 2014 7:10 pm
the ammeter tells me when the alternator has tossed a belt.. almost instantly..
maybe a volt meter would do the same .. but driving all old Chrysler cars I am used to looking at the ammeter.
 Post subject: Yep...
PostPosted: Sun May 04, 2014 8:39 pm
Yep, nothing stares at a mopar driver better when a belt goes, the red wire on the alt burns through, or the alt is toast than seeing the amm needle take a nose dive to "D"... (next after that in a couple minutes the temp gauge goes to "H" if it was the belt...been there).
