It is currently Sat Nov 28, 2026 12:39 am
PostPosted: Sun Apr 06, 2014 8:02 pm
I have most of the specs in my signature, nothing too fancy here on my slant, no heated or electric choke, have a button on the dash - when rebuilt I put .030 pistons with, stock conn rods, stock pushrods, new OEM spec lifters, a new COMP cam from Summit, new oil pump, new mech fuel pump, cleaned out old dizzy but nothing new but cap, points, and condenser there, new plugs and wires, new sump in the pan cause idiot at machine shop broke it after he said he could get it out no problema:roll:, a new front seal on the trans, new timing gears and chain, and put it in because my legs were getting tired of pumping bike pedals to haul me to work(I now know how a piston feels)...and an A904 trans that is probably worn out and close to kickin the chikin, and the original 1945 Holley that I had to jimmy rig back together after discovering the PO had stripped the threads and screws out whilst rebuilding to fix leaks and unresponsiveness and idling problems...I've dumped about 3 grand into the motor so far and I'm hoping to make this as reliable as possible and still be able to have fun but I'm still getting the teeth on my gears so to speak. What would you guys recommend that wouldn't require me dumping another 3 grand into the motor. I've considered replacing my points in the carburetor with electric ignition but I am scared that it will bugger up and you can't sandpaper or swap that like you can condenser and points... I also was curious about good exhaust/muffler options, different carb pros and cons (like Holley, Edelbrock, or Weber), and my buddy that was helping me get it together said he "centerlined" the cam when we put it in to make more torque because I live in a camper and he thought it would be wise. What exactly does that term mean and what did he do? I'm a little stupid I reckon...
Also this is the cam installed on stock lifters and rods: http://www.summitracing.com/parts/cca-c ... /overview/
I've been looking at a Weber 32/36 and I'm liking the thought of it but where would I get an adapter plate from? A couple of dozen searches worded in every possible combination have yielded no results...Hm. I'm assuming this is a fab job, but yet again would I just need to provide them with pics and my intake or another similar intake and let them go from there or do I need some number specs to hand them?
I've also been going back and forth over using a Raptor muffler which is what I used on an S-10 and was good for the price and seemed more of a fit for a six cylinder, or going big and upgrading to a Magnaflow or Flowmaster...It has a Thrush Glasspipe on it now. Heard those are bad for backpressure....
Basically, critique me, and give me some advice dangit - I want more power!
1984 D150 with a 225 .30 over, A904. Dash choke, points conversion, new carb, new camshaft, new lifters, new pistons, new oil pump, balanced crank.
PostPosted: Wed Apr 23, 2014 10:40 am
Your truck is an '84. It did not come with points and condensor originally. It would've had an electronic ignition distributor without advance weights in it, and a "lean burn" computer to run it.
Sounds like someone did some part swapping.
I'm guessing this is a typo, as points aren't in carbs :lol:
Like I said above, someone did some part swapping to put a points and condensor distributor in your truck, assuming that's what it actually is. Can you post a photo of the distributor without the cap on it?
If you are actually running points, converting to EI will help you gain reliability and a little bit of power to boot. I won't even bother with points anymore (unless they are on a Briggs and Stratton)
Do some searching on the board, there are PLENTY of exhaust threads here. The typical approach is 2.5" from manifold back, with a muffler of your choice inserted somewhere between the manifold and the rear bumper.
Again, the search button is your friend!
Not stupid, just unfamiliar with the concept I suppose. :D
"Centerlined" is probably not the best term to use there. If it means what I think he means, it's that the cam was installed "Straight Up". This means that the cam is not Advanced/Retarded vs. the crankshaft.
Typically, to get a little more torque at the bottom end of the RPM range, you'd "Advance" the cam a couple degrees. If you wanted more high end power, one would "Retard" the cam timing.
You stated that you have a Holley 1945, which is a single barrel carb. You can have an adapter plate made to fit the Weber (or anything really) to the 1 barrel carb intake, but you won't get the full benefit of the bigger carb while trying to run it through a straw.
A better bet would be to get a 2 barrel manifold (or get a spare manifold to modify if you want to go that route, that way you aren't left without a running rig) and corresponding wisely chosen carb.
Your truck is an Automatic, and the automatic transmission kickdown/shift lever is actuated by the throttle linkage, so if you change the carb, you will need to fabricate an effective way to actuate the linkage for the transmission.
So long as it isn't plugged, I don't think you can really go wrong.
Pop onto YouTube and look up some slant six exhaust and car videos; you can find someone that has a car with the sound you like. It's like muffler shopping!
Take two of these and call me in the morning. 8)
~THOR~
PostPosted: Wed Apr 23, 2014 6:16 pm
Thanks, yeah that was definitely a typo, I wasn't firing on all cylinders whilst typing away I reckon. I've been hunting mufflers on Youtube as of recent and think I have done enough homework on a Super Six to think I want to try that route with a Super Six intake and a Holley 2280 or something like this:
http://www.ebay.com/itm/310931307681?_t ... EBIDX%3AIT
and put a new fuel pump in, just to be safe on that with some new lines. I will consider the electronic ignition, just don't like the idea of my truck not running because of a solar flare, EMP, etc. I've not located one other than at Oreillys for about $100 is there a better option? Still needs a lot other than that just trying to do things one at a time and do them right. Thanks for the help will post a distributor pic tomorrow
PostPosted: Wed Apr 23, 2014 7:44 pm
That one looks correct, but be careful, as there are 2 versions of the Carter BBD, one for V8 (think 318), and one for the Super Six. They will "swap" but there are a couple key differences:
The throttle linkage is different between the two enough that the transmission kick down linkage won't bolt in with the factory bracket (assuming you can find a factory super six manifold and transmission kick down linkage), the choke rod is clocked different y such that if you found and tried to use the Super Six choke spring and rod, it won't clip right on, and you'll need to do some tuning on the carb (setting the metering rods mostly).
It's definitely do able, and if you have fabrication skills/equipment it can be done fairly easily in my opinion.
~THOR~
PostPosted: Fri Apr 25, 2014 12:10 pm
OK will make sure not to get the wrong one. Here is a pic of the distributor and the bay so far. Sorry it took so long, I sent them twice and waited forever, probably my flip phones' fault
 Post subject: More power!
PostPosted: Sun Apr 27, 2014 11:47 am
The biggest power adder is compression. That makes a huge difference and can make you think you have a 318 under the hood.
The second is 2.25" to 2.5" exhaust with a FlowMaster muffler.
The third is recurving your distributor. The best option would be to go with an HEI set up and a part #3874876 76-78 Super Six distributor, but you can run a MOPAR ECU with out the resistor if you buy a 3 ohm Pertronix coil like I did.....
It works very well and has served me well for many years as an interim solution to the HEI. My HEI is mounted but not wired.
You may want to do the SL6 Dan's fuel line mod and use the plugs he has suggested. Both of these mods help on hot restarts.
Going with a bigger carb just won't do it unless the rest of the system will support the extra flow and light the fire effectively to create the power your looking for.
Any idea of the gear ratio of your rear-end? That can make a big difference as well.
Last edited by Aggressive Ted on Sun Apr 27, 2014 11:53 am, edited 1 time in total.
PostPosted: Sun Apr 27, 2014 11:52 am
I have seen discussion of electronic ignitons and points ignitions in relation to EMP concerns on several boards. Does anyone really make their decision of what ignition system to install based on the possibility that an EMP would disable their vehicle? It seems like a pretty ridiculous basis to select points ignition. Right up there with choosing not to run a fan out of fear there will be a new ice age.
The carb in that ebay auction is a V-8 carb, so hopefully you didn't buy it.
Ted is right- start with installing a modern ignition system, then check your rear axle gear ratio, then start thinking about things like compression. You can do a great deal with the stock one barrel carb.
PostPosted: Sun Apr 27, 2014 3:44 pm
I don't want to make the decision solely on that, it's just an added bonus in my mind - also I want to be sure I will be getting better performance over points, never really had it explained I guess. I will look into the HEI and fuel mod first, that sounds like the best way to start, and I need to do something about my exhaust too. I appreciate the help, I'll post pics and keep you updated as I go.
Also, what do you mean "recurve" the distributor? Another unfamiliar term. :roll:
PostPosted: Sun Apr 27, 2014 5:36 pm
My point is how often do electronic ignitions get knocked out by an EMP pulse? When was the last time you heard about it? What is the likelihood of an EMP happening that will knock out the ignition system on your truck? Finally, if an EMP were to happen that was strong enough to damage the ignition on your truck, I think you would have bigger issues than driving your truck. Making your choice of ignition systems on the possibility of an EMP occurring is just silly.
Anyway, recurving the distributor refers to replacing the internal components of the distributor to adjust the rate at which the timing is advanced as RPMs in crase and as vaum is applied to the vacuum advance pod. Search the board for distributor recurve or lookin the FAQ section for the electronics forum.
PostPosted: Sun Apr 27, 2014 6:39 pm
OK, I will look in the FAQ section as well, I understand your point btw - I sound crazy . However, even if I change over I will still carry points just because I know they aren't as sensitive, I don't know what will happen but I do pay attention to the news and have seen where DHS is buying millions of rounds of ammo and hardware (including emp guns), so I feel more or less comfortable knowing my government is preparing for some sort of unrest.
However, I'd prefer to keep this and all my conversations non-political as my purpose on this forum is only to try and learn more, not debate.
PostPosted: Sun Apr 27, 2014 6:46 pm
I think points get a bad rap. Here's why, I had a points system in my 390 FE. I always use quality points and set the dwell with a meter. I bought into the electronic ignition conversion pitch and switched it over. Nota. No gain in power, performance, or economy. You couldn't tell I did anything.
I suspect what happens is people with a good running engine don't think about it, then when the points and/or condenser start to fail they do the conversion and end up thinking the improved performance was the conversion, not the old sloppy points they were running.
Now, I'm talking about drivers here, not racers. I know points pose a problem with floating in racing so if you spend time at the track electronic is the way to go. But for daily driving, let me say this, had I known, I'd still be running points in my 390 and saved the money.
That being said, there are another couple of, uh, points to consider. Quality points sets are getting harder to find, good stuff like Blue Streak. Most places are carrying really really cheap-o Chinese junk that just isn't going to last.
Secondly, the distributor in a BBF is a lot easier to access then the one on a slant. So I can see the temptation of going electronic just so you won't have to mess with the points in a dizzy that's buried deep down in the hole. Myself, I just pull the dizzy when I replace points in my Valiants.
PostPosted: Sun Apr 27, 2014 7:18 pm
That's something I have noticed as well, seems like I set the points more frequently (I set mine with the dwell method as well), maybe just me - but have long suspected cheap parts. I just use this to drive and pull my camper, might go up a steep hill here and there, nothing crazy...
Just wanted to know a general list of what you guys all ran, and use that as a reference to explore different options people used, kinda 'window shop' before I buy, just sayin
PostPosted: Sun Apr 27, 2014 9:35 pm
Yes!
PostPosted: Mon Apr 28, 2014 11:40 am
Yes!
Maybe? :P
PostPosted: Mon Apr 28, 2014 11:51 am
Yes!
Maybe? :P
Definitely:
http://www.slantsix.org/forum/viewtopic.php?t=38471
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 4 guests
