It is currently Fri Nov 27, 2026 4:59 am
PostPosted: Wed Apr 16, 2014 5:11 pm
Heres a lil somethin im working on for my rockcrawler build..78 225/904 combo infront of a t100 tcase and toyota axles in a 97 tracker 4 door..
Anywho..i figured id share some pics of the build...ported late head. Stock valves. Stock shortblock..i will end up with a erson 280 grind from oregon..sheetmetal intake(awaiting flange), 6-2 shorties with 1-5/8 primaries..flat merge collector..not many of these on the net..so here ya go..
Oh..carbs are kehin cvk 34mm
PostPosted: Wed Apr 16, 2014 5:20 pm
Not sure how yet to post images directly...
https://fbcdn-sphotos-f-a.akamaihd.net/ ... 6888_o.jpg
PostPosted: Wed Apr 16, 2014 8:09 pm
[Image
[/img]
PostPosted: Wed Apr 16, 2014 8:11 pm
Hit the img icon at the top of the reply area, paste your URL, and hit img again. :D
 Post subject: Cool
PostPosted: Thu Apr 17, 2014 6:07 am
Cool
65 Coronet, 4 bbl, .060 over, mild cam.
66 Valiant, Black, 3spd, Hyperpak, headers.
works in progress...
PostPosted: Thu Apr 17, 2014 8:48 am
PostPosted: Thu Apr 17, 2014 8:51 am
Hey it worked!..spaces between img and url were my issue..thanks 'zilla!
Better shot of the header..not quite finished..but you get the idea..made from 100% recycled header scraps!..in fact..i have maybe 25$ in consumables costs in the entire induction/exhaust thus far...ima csob
PostPosted: Thu Apr 17, 2014 9:03 am
Based on existing data on the interweb..the cv's flow around 240 cfm..just about right for what im doin..case anyone is interested...i chose cv's because they are super tuneable..dead simple/reliable, modern, and most important..theyll run at rediculous angles..
PostPosted: Fri Apr 18, 2014 12:17 am
Car Model: 1966 2D Dart
Excellent craft both for intake and exhaust. If carburetors are limiting which I assume heavily, next step should be 40mm CVs which should be sourced from Harley-Davidson motorcycles. They are all the same 40mm size from late 80's up to injection engines and widely available used.
PostPosted: Fri Apr 18, 2014 11:34 am
Thanks guys!..34s are WAY small for 225" imo..but plans are for a surge plenum and pilot tubes for blowthru..as well as a boost ref reg...part throttle driveability and strong metering signal off boost were my goals. I have a m90 i will run remotely along wth a minicooper s bypass(ford m90)..stay tuned..ill post more as i progress..
Im familiar with the 40s..ive done a few itb/ gsxr carbs in suzukis as well as a 40cv on my. Previous 2 door tracker to replace a failing tbi..they may be a possibility down the road.
PostPosted: Fri Apr 18, 2014 11:40 am
Heres a couple previous personal builds of mine..always liked underdawgs..started with a 68 fastback cuda with a 225 @ 12 years old. Im 32 now.ive been between mopars and zuks my entire life.
PostPosted: Fri Apr 18, 2014 11:43 am
PostPosted: Fri Apr 18, 2014 11:50 am
Spent ten years with rod hall international as a teen..from the dodge to the hummer years!..mopars for life..ive got a few mopar badges(tattoos) to prove it haha
PostPosted: Fri Apr 18, 2014 11:54 am
PostPosted: Fri Apr 18, 2014 12:00 pm
