It is currently Fri Nov 27, 2026 9:28 pm
 Post subject: Ultimate Block prep
PostPosted: Tue Apr 29, 2014 8:49 am
I am looking into finally building my 6. I'm not overly concerned with cost or time; I would like to do everything once and do it right. What are the tips and tricks I should employ to sort out a solid Street engine when it comes to modifying the engine block and rotating assembly?
PS - Not overly interested in keeping things stock. I'm on the order list for a AussieSpeed Hurricane intake and I already have a set of Hooker Headers I'm going to have to modify to fit properly with this combination. I'd like to go with a hydraulic camshaft and EFI in the future; I'm sure the details about the internals will be subject to change as new parts are found and technology is employed.
PostPosted: Tue Apr 29, 2014 10:25 am
See Doc's articles in the articles section of the website.
PostPosted: Tue Apr 29, 2014 11:07 am
Have you reviewed the SL6 Block article?
http://www.slantsix.org/articles/dutra- ... blocks.htm
PostPosted: Tue Apr 29, 2014 11:46 am
Thanks guys, I appreciate the help. Looks like I've got plenty of reading to do on the topic tonight :-P
PostPosted: Tue Apr 29, 2014 12:03 pm
I'm also on the lookout for the best high lift camshaft for torque gains over horsepower. Lord knows the average engine spends over 80% of it's life at low rpm while driving around, might as well take advantage of it and build for some grunt.
 Post subject: Er....
PostPosted: Tue Apr 29, 2014 5:17 pm
This is pretty subjective...
If you are building a "Lou" (say 10:1 SCR), then the Erson 270/270 provides good lift and duration with low end and all the top end....and have good mileage to boot...need to couple with correct rear gearing.
I can say I have lots more torque than the above torque with the OCG549, and have 12:1 SCR to support it, and no mileage estimate to say how that works on Super (gets lowsy mileage going form pit to light then back to pit again.)
Low end torque builds like Teds, are moderate lift and lower duration to build cylinder pressure.
unless going turbo, there is a throw over value where a high lift low duration cam will be gutless at low rpm, and pick up power on the high end... (I tried a Comp Cam CCX 256 custom grind wanting the 25X short duration cam for all around torque but more lift than .435...at .466 lift the cam was OK at idle to 1800 rpm, but really shined after 2000 rpm... (the comp 252 would spank it, if the contest was measured from idle to 1500 rpm at the light...and I degreed it in 5 degrees advanced)...
PostPosted: Thu May 01, 2014 6:07 pm
What is this engine going in? Are you planing on stroking it?
