It is currently Sat Nov 28, 2026 1:21 am
PostPosted: Thu May 01, 2014 9:54 am
For background, back in 2004 I had my engine rebuilt at a little mom & pop shop which is now out of business. I don't really remember what all was done to it (other than the intent being to build it for daily-driving), so I had no idea what camshaft they put in.
Well, I was bored the other day and looking back through my old posts on this forum from when I was a clueless idiot college student and not yet an idiot gearhead who should know better. Thank Iacocca, that younger version of me unknowingly committed the numbers on his cam to the Cloud.
http://slantsix.org/forum/viewtopic.php ... c&start=30
"448 lift, 264 duration, and 109 lobe." In a previous post in that thread, I also identified it as an Isky cam, but at this time I can't find any cams on the Isky website for the Slant 6. Looking at other websites, however, it seems like these numbers are a bit on the high side.
I've never been able to get this engine to idle very smoothly, so I'm curious how hot this cam really is. I thought it was supposed to be pretty mild, but now I'm not so sure. .448 looks like a lot of lift for a stock motor.
I'm also curious (still) how the valve lash should be set, if it should be different from stock. At our first LeMons race, Lou recommended setting the lash fairly loose, but I don't know if that was specifically for endurance racing or if it should normally be set that way for the street as well. I wanna say he set it to something like .015 intake and .028 exhaust.
Finally, any input on how the rest of the motor should be set up is welcome. I assume the static CR is still relatively stock, so maybe some head milling wouldn't be a bad idea. On the other hand, how would this cam work with a turbo? (The race team is throwing around several crazy ideas) My current intake is a stock super six manifold with a Holley 350 (2300), exhaust is a stock later-model exhaust manifold with a 2.25" pipe.
Escape Velocity Racing
PostPosted: Sat May 03, 2014 10:26 am
That is sort of a midrange cam. Should give you a nice idle if everything else is up to snuff. Lash specs will probably be in the range we set them, but some playing around would be a good idea. Try closing up the exh lash by 0.003" increments and see where the idle get substantially worse when it gets nice and hot, then back off 0.002-0.004
" and that is your best setting. Int lash could even be a bit looser, but again, playing around is best.
If you are at stock static CR, then milling 0.090" or more would be good to get you up over 9.0:1 static with that cam. You will gain a lot of HP going from 7.5 or 8:1 stock static CR to over 9.0, and even more with a bigger-than-stock cam like you have. If turbo, then leave CR where it is and go to a stock cam for minimal overlap.
Users browsing this forum: Bing [Bot] and 5 guests
