It is currently Mon May 18, 2026 9:57 am
PostPosted: Wed May 07, 2014 12:15 pm
I have 71 Dart with front disc breaks. Is the back spacing 4.00 or 4.25??
Also, I am having my rims widened. Should I go 6" or 7" wide?
PostPosted: Wed May 07, 2014 12:48 pm
Your original wheels have less than 4" backspacing as they are only 4.5" wide. The 15x7" wheels used on police cars are 4.25" backspacing or .25" positive offset (ET6mm). On a car with the '73+ disc brakes (breaks is an action which destroys) 15x7" with 4.25" backspacing works great. You may be able to use slightly less backspacing with Kelsey Hayes brakes, but the biggest I went with the '72 Duster was 14x7" slotted mags with a 215/60R14 tire.
How much does it cost to have the wheels widened any more?
PostPosted: Wed May 07, 2014 1:00 pm
If you run 6 or 7 inch wide rims in the front, you MUST get backspacing of at least 4 inches and you will be runnign very skinny tires to clear the frame.
For example, my brother has a 74 Duster that is running 68 Dart front fenders. The wheel opening on the 68 fenders is a bit smaller than your 72 fenders, but pretty close.
The Duster currently has 15x7 rims with about 4 inches of backspacing. The biggest tire that fit on the rims and that clear the fender and the frame are 205-50-15. With the later and larger wheel opening you could probably get away with 215 or even 225 width and 60 to 70 ratio sidewalls, but that isn't much bigger.
 Post subject: Back spacing...
PostPosted: Fri May 16, 2014 9:37 am
I resenting bought a 14" rally wheel with a 4.00 back spacing and the wheel would not clear the factory disc break caliper. Does that mean I need a 4.50 beach spacing? Collin's in Bellflower widens wheel for $60 each painted.
PostPosted: Fri May 16, 2014 12:08 pm
With the limited information being given I'm thinking the wheel that wouldn't fit over the brake caliper was not a Chrysler-made wheel. I believe there are Magnum 500 wheels that fit drum brake cars only.
 Post subject: rally wheel
PostPosted: Fri May 16, 2014 3:49 pm
Hi, the wheel I tried to fit was the 1971 dodge Rally wheel 14 x 6 with 4.00 back spacing.
PostPosted: Fri May 16, 2014 5:48 pm
With factory Rally wheels and factory disc brakes you should have zero issues.
 Post subject: 2¢ worth
PostPosted: Sat May 24, 2014 12:49 pm
I put 205/60-15s on Magnum 500s onto a 73 Dart Custom that had disk brakes. The Magnums had 4¼" back spacing. No problem with clearance front or rear.
I have 235/60-15 on cop car wheels on a 72 Demon with BBP disk brakes. Wheels have same BS as Magnums. No problem with rear clearance. Front wheels are extremely close on outside. Fenders hung a little wide to ease situation. Admittedly, the front end is set to the low side of factory tolerance. Things might be easier if I went to a more middling setting.
:idea: If I had to do it over again, I'd probably would go with no more than a 225/60-15 tire on a 7" wide wheel with 4¼" back space.
You can't fix stupid. - Ron White
