| Back spacing and wheel widths?? https://slantsix.org/forum/viewtopic.php?t=55293 |
| Author: | dodgedarren [ Wed May 07, 2014 12:15 pm ] |
| Post subject: | Back spacing and wheel widths?? |
I have 71 Dart with front disc breaks. Is the back spacing 4.00 or 4.25?? Also, I am having my rims widened. Should I go 6" or 7" wide? |
| Author: | Joshie225 [ Wed May 07, 2014 12:48 pm ] |
Your original wheels have less than 4" backspacing as they are only 4.5" wide. The 15x7" wheels used on police cars are 4.25" backspacing or .25" positive offset (ET6mm). On a car with the '73+ disc brakes (breaks is an action which destroys) 15x7" with 4.25" backspacing works great. You may be able to use slightly less backspacing with Kelsey Hayes brakes, but the biggest I went with the '72 Duster was 14x7" slotted mags with a 215/60R14 tire. How much does it cost to have the wheels widened any more? |
| Author: | Reed [ Wed May 07, 2014 1:00 pm ] |
If you run 6 or 7 inch wide rims in the front, you MUST get backspacing of at least 4 inches and you will be runnign very skinny tires to clear the frame. For example, my brother has a 74 Duster that is running 68 Dart front fenders. The wheel opening on the 68 fenders is a bit smaller than your 72 fenders, but pretty close. The Duster currently has 15x7 rims with about 4 inches of backspacing. The biggest tire that fit on the rims and that clear the fender and the frame are 205-50-15. With the later and larger wheel opening you could probably get away with 215 or even 225 width and 60 to 70 ratio sidewalls, but that isn't much bigger. |
| Author: | dodgedarren [ Fri May 16, 2014 9:37 am ] |
| Post subject: | Back spacing... |
I resenting bought a 14" rally wheel with a 4.00 back spacing and the wheel would not clear the factory disc break caliper. Does that mean I need a 4.50 beach spacing? Collin's in Bellflower widens wheel for $60 each painted. |
| Author: | Joshie225 [ Fri May 16, 2014 12:08 pm ] |
With the limited information being given I'm thinking the wheel that wouldn't fit over the brake caliper was not a Chrysler-made wheel. I believe there are Magnum 500 wheels that fit drum brake cars only. |
| Author: | dodgedarren [ Fri May 16, 2014 3:49 pm ] |
| Post subject: | rally wheel |
Quote: With the limited information being given I'm thinking the wheel that wouldn't fit over the brake caliper was not a Chrysler-made wheel. I believe there are Magnum 500 wheels that fit drum brake cars only.
Hi, the wheel I tried to fit was the 1971 dodge Rally wheel 14 x 6 with 4.00 back spacing. |
| Author: | Joshie225 [ Fri May 16, 2014 5:48 pm ] |
With factory Rally wheels and factory disc brakes you should have zero issues. |
| Author: | 2 Darts [ Sat May 24, 2014 12:49 pm ] |
| Post subject: | 2¢ worth |
I put 205/60-15s on Magnum 500s onto a 73 Dart Custom that had disk brakes. The Magnums had 4¼" back spacing. No problem with clearance front or rear. I have 235/60-15 on cop car wheels on a 72 Demon with BBP disk brakes. Wheels have same BS as Magnums. No problem with rear clearance. Front wheels are extremely close on outside. Fenders hung a little wide to ease situation. Admittedly, the front end is set to the low side of factory tolerance. Things might be easier if I went to a more middling setting. |
