It is currently Sat Nov 21, 2026 2:10 am
 Post subject: reared noise (II)
PostPosted: Sun May 04, 2014 5:34 pm
I have a 7 1/4 rearend. When I bought my '67 Dart a few years back, the rearend was making noise so I took it to a tranny/rearend shop and they replaced the axle bearings and gear set. After that it was pretty quiet for some time, although the new gear set had a rather subtle hum to it. I assumed this was new gears wearing in or something. Now, after a couple years, it just started making more noise again. It's sporadic, sometimes no noise, sometimes pretty decent hum back there. I'm sure my leaf springs are too soft, so maybe the angle in the drive line isn't optimal.
I have an 8 3/4 rebuilt that I'll put in (still collecting parts), but for now...is there an adjustment in the rearend they didn't get right, do rearends need adjustment in such a short period or is something else likely worn out now?
I'm not having any issues other than the noise, sometimes it's a pretty loud hum, sometimes it's quiet as a church mouse.
BTW, when I swap out for the 8 3/4 there will be a free 7 1/4 rearend if anybody is interested.
Thoughts?
Brian
PostPosted: Mon May 05, 2014 5:41 am
Check fluid level.
 Post subject: Thanks
PostPosted: Thu May 08, 2014 5:30 pm
It's getting louder, I took it in to have it checked...hopefully not too late...
PostPosted: Sun May 11, 2014 3:44 am
With the domination of FWD over the last 30 years it is getting harder and harder to find someone who knows how to work on these properly. I am going down the same road now. I paid a lot to have my 8.25 rebuilt and it is still noisy. Let us know what you find out.
Sam
PostPosted: Sun May 11, 2014 5:42 am
Go to some one trustworthy that works on trucks / 4wd's They are alll still ring an pinions in them....
PostPosted: Mon May 12, 2014 3:35 am
There is an idea. Thanks. Hope to see you on Saturday.
Sam
PostPosted: Tue May 13, 2014 9:48 am
Sam where did you get your front bumper lip/air dam? Or did you make it? Im inlove :lol:
19 Years young with a passion for all things old.
"Four doors for more....screaming passangers..(;"
"There's no replacement for displacement, but my \6 is still cooler than your V8"
PostPosted: Tue May 13, 2014 10:52 am
There is a thread about it that is maybe a year old. It is a cut down Chebbie pick up spoiler. I'll try do find it later.
Thanks for the compliment.
Sam
PostPosted: Tue May 13, 2014 1:12 pm
When people like that are getting hard to find in your area.. time to learn how to do it yourself.
A few simple tools from http://www.ratechmfg.com/pinion%20setting%20tool.htm can help.
More infos here:
http://www.ratechmfg.com/toc.htm
http://www.ratechmfg.com/chrysler.htm
http://www.ratechmfg.com/myth.htm
I setup my own..
IF it makes noise most likely the Pinion depth is wrong. one of the ratech Pinion depth checkers and a factory service manual can help here.
It does help that I have a press downstairs for pressing the bearings on and off the Pinion Stem. Its not a hard job to do. Just a few tools, micrometer, Depth checker and a dial indactor are all that is needed.
