| When Switching to an Electric Fan?? https://slantsix.org/forum/viewtopic.php?t=55444 |
| Author: | Greg Ondayko [ Mon May 26, 2014 7:39 pm ] |
| Post subject: | When Switching to an Electric Fan?? |
When Switching to an Electric Fan is it of any benefit to keep the Old Fan shroud that MA Mopar put around the thermostatic de-clutching fan from 1979? Greg |
| Author: | slantvaliant [ Wed May 28, 2014 2:17 pm ] |
A shroud properly fitted to the fan and radiator really helps the cooling. Now, whether you can get that one to fit the new fan is another question. I wish I had room for a shrouded fan ... |
| Author: | Pierre [ Wed May 28, 2014 5:27 pm ] |
Electric fans sit very close to the core and have their own shroud. If your removing the stock mechanical fan and clutch I see no reason to keep the stock shroud. |
| Author: | Greg Ondayko [ Thu May 29, 2014 4:29 am ] |
Quote: Electric fans sit very close to the core and have their own shroud. If your removing the stock mechanical fan and clutch I see no reason to keep the stock shroud.
That's What i did on the inital install, but I figured I would ask to see what the consesus was.Thank you! Greg |
