It is currently Fri Nov 20, 2026 2:40 pm
PostPosted: Tue May 27, 2014 7:15 am
Axles and carrier for sure. Any gotchas?
PostPosted: Tue May 27, 2014 7:33 am
Custom axles aren't a gotcha? Have you looked to see if the bearings are the same? If the 29 spline axle bearings have a larger OD they won't fit the older housing. Same with the carrier bearings.
May I ask why you contemplate such a move?
PostPosted: Tue May 27, 2014 7:41 am
Sure, I am pondering completely rebuilding the rear axle. I want to upgrade where I can.
PostPosted: Tue May 27, 2014 7:48 am
Oh. Sounds like a way to spend a lot and get little in return. I used to get caught in this trap myself. What's wrong with the rear end now?
PostPosted: Tue May 27, 2014 7:53 am
I think its locking up after it warms up.
I started a thread in this forum but no replies.
PostPosted: Tue May 27, 2014 8:31 am
I read that post, but wasn't clear about what's happening. Is the vehicle not able to be driven when it locks up like a ring and pinion problem or is it that the axles are locked together like a differential problem?
PostPosted: Tue May 27, 2014 8:47 am
It acts like a diff problem. If I go exactly in a straight line, its ok. Even the slightest low speed turn will cause binding and make a racket. This is after a 30 minute drive. All is well when cold.
Hey thanks for your knowledge. The conversion can't be done easily. I'm taking her down to the shop. They are going to diagnose the lockup problem and we'll go from there.
PostPosted: Tue May 27, 2014 2:12 pm
If all you need to do is smooth out the turns we might be able to save you a lot of time and money. I'm concerned about the friction modifier you used. Do you have a part number for the product?
