MS2 timing offset variable?
https://slantsix.org/forum/viewtopic.php?t=55477
Author:  pishta [ Fri May 30, 2014 8:50 pm ]
Post subject:  MS2 timing offset variable?
My sensor is about 2 off TDC, is there an offset you can plug into MS to compensate for a stationary sensor (that should have been adjustable but I thought I nailed it) ? I thought I saw something like that in there. Sort of a global timing offset?
Author:  Pierre [ Fri May 30, 2014 9:19 pm ]
Yes - using EDIS there is at least. Called Trigger Offset or Advance Offset. Which tuning software are you using? In Tuner Studio its under tools > Trigger Wizard.
http://www.diyautotune.com/tech_article ... how_to.htm
Author:  pishta [ Sat May 31, 2014 10:45 am ]
sweet! whats the max value? I know EDIS only does 10 degrees limp home but this allows a few mm wiggle room on mounting a VR pickup or adjusting a slipping trigger wheel.
Author:  Matt Cramer [ Mon Jun 02, 2014 9:57 am ]
If it's within 5 degrees, I wouldn't worry about it too much.
