It is currently Tue Jun 16, 2026 2:28 am
PostPosted: Sat May 31, 2014 3:06 pm
Car Model: Slant Six M37
I'm pleased to now be registered with the \6 forum, and beginning to learn. My present question is around a \6 truck engine I just looked at. It is installed in a 63 one ton Dodge, and seems to run really smoothly..
Here is my real question: My only experience with mechanical lifters is in a 230 flathead and the lifters make some noise when cold. This truck engine did not have any lifter noise. NONE (I do not know if it was warmed up previously) but the owner did say he had someone tune it up 10 years ago when he bought it, and has not driven it more than 200 miles a year since..
If the lifters are too tight, it will burn an exhaust valve right? would it also cause low power output? although it runs nice, it does not seem to have much grunt. I realize that a 7000 lb truck will not be quick, fast or sporty in any manor... but my 230 flathead in a 46 power wagon will run circles around this thing
I am considering driving it 120 miles to get it home.. and do not want to burn the exhaust valves in the process. the present owner seems to know something about vehicles, although claims not to know much in detail, that may be true, and it may be partly salesmanship. he seems certain that the valves are adjusted correctly... and maybe they are..?
Any advice and perspective welcome,
thanks
Jase
PostPosted: Sat May 31, 2014 5:44 pm
.010" clearance on the intake valves and .020" on the exhaust. Hot and running is the preferred method. It's a little messy, but it's worthwhile.
PostPosted: Sat May 31, 2014 7:31 pm
Ok,
I'm all for setting the valve lash, Can it wait 120 miles? or do I do it in his front door yard?... OR will a compression test tell the tale and decide upon the results?
PostPosted: Sat May 31, 2014 9:00 pm
Just adjust it.
You can set it at .012 I and .022 E cold.
PostPosted: Sun Jun 01, 2014 5:11 am
Ok, I'm on it. Best way to find out anyway. Thanks
PostPosted: Sun Jun 01, 2014 7:03 am
Welcome to the Forum! Post some pictures of your truck when you get a chance. Valve adjustments: 4th post down! http://www.slantsix.org/forum/viewtopic ... ght=#72139
1964 Dart GT
Users browsing this forum: Ahrefs [Bot] and 3 guests
