It is currently Sun Jun 14, 2026 6:58 am
 Post subject: Dropping oil pan woes
PostPosted: Tue Jun 03, 2014 5:07 am
You guessed it, the question is now that I've got all the bolts out and the tranny brace out of the way how do I get the oil pan the rest of the way out? It's my 2wd 75 D-100 by the way and I'm trying to change the gasket and paint the pan while I have it off. I thought you could get these out without taking motor mounts loose on these trucks. If there's a way can someone please enlighten me? Thanks, Sam
1975 Dodge D100 2wd Reg.cab 225/6, 727auto, 3.55 gears, Cat delete with 2.25" Thrush Exhaust, Dist recurve by DI, 9.1 comp, Factory aluminum 1bbl intake with heatshield, 63 Jet, Delete ballast with Pertronix Flame Thrower 3ohm coil
