It is currently Fri Jun 19, 2026 7:02 pm
 Post subject: 7.25 axle collar source
PostPosted: Tue Jun 03, 2014 7:15 am
Cross posted this to fabo but I thought you guys might be able to help as well. I'm replacing the rear outer bearings and seals in the 7.25 axles and I already bought the bearings and seals and gaskets, but now I realize there is a collar that has to come off and get replaced. Anyone know where to get these or what to look for? If I made a bonehead move and I need to get a kit with different bearings and collar and seals, I guess I can do that as well, but I can't seem to locate anything besides diff kits.
1970 Plymouth Duster, 198 Slant Six, Super Six setup w/ EI conversion
http://www.semisynthetic.net/kill-9/gal ... p?album=34
PostPosted: Tue Jun 03, 2014 8:02 am
Axle bearings come with the collar if you buy them from an auto parts source. Did you order by bearing number perchance?
PostPosted: Tue Jun 03, 2014 8:48 am
I got the RWF34R from amazon: http://www.amazon.com/gp/product/B000BZ ... UTF8&psc=1
I should go check the box I guess.
PostPosted: Tue Jun 03, 2014 8:54 am
Yep, you were right, it was in there. Doh! Thanks!
PostPosted: Tue Jun 03, 2014 2:02 pm
Thanks for the chuckle!
