It is currently Wed May 27, 2026 2:35 am
 Post subject: 1961 Valiant
PostPosted: Wed Jun 11, 2014 4:35 am
The horn has stopped working.
The mechanic had the steering wheel off to fix the indicator but now the horn only 'clicks' when pressed. Horn wire is connected.
Any ideas please!
PostPosted: Wed Jun 11, 2014 4:50 am
if the horn clicks it is at the horn ,they have a small adjustment screw.
I would lightly tap the horn when it is clicking, if that does not help you will need to turn the screw slowly to see if you can get sound again, Lawrence
