| Wire GA Help Needed https://slantsix.org/forum/viewtopic.php?t=55804 |
| Author: | DAJUJ [ Wed Jul 16, 2014 5:03 pm ] |
| Post subject: | Wire GA Help Needed |
I am beginning to put together an HEI conversion setup for my 63 Valiant. Today I received the recommended electronic distributor to go along with other parts I've collected from another member on this board. Other than a post setting out the wire gauges to use when using a relay, I've not seen anything on what gauge wire to use elsewhere such as connecting the distributor to the HEI 4-pin module, module to the coil, etc. etc. Hopefully, one of you can help me. Thank you. |
| Author: | Joshie225 [ Wed Jul 16, 2014 5:48 pm ] |
14 AWG is plenty and 16 AWG would be fine on the power side. The signal from the distributor can be 16 or 18 AWG. |
| Author: | DAJUJ [ Wed Jul 16, 2014 6:14 pm ] |
Thanks... |
