| Water passages blocked? https://slantsix.org/forum/viewtopic.php?t=55848 |
| Author: | CNC-Dude [ Fri Jul 25, 2014 5:08 pm ] |
That is a typical casting issue of all auto brands not just Chrysler. I think you keep expecting to find Ferrari type craftsmanship in a vehicle that probably didn't cost much over $3000 new, and your just not going to find it. Where the bowls have been enlarged from the valve job, you will need to clean that up and blend with a die grinder and smooth up with a cartridge roll abrasive. |
| Author: | Sam Powell [ Fri Jul 25, 2014 7:25 pm ] |
It can't hurt to clean that flash out of the water passages, and might help. It will make you feel better. Sam |
| Author: | 1930 [ Fri Jul 25, 2014 11:59 pm ] |
Ok thanks guys, its better to ask before I cut rather than after and make a mistake. |
