It is currently Mon May 11, 2026 10:52 am
 Post subject: Water passages blocked?
PostPosted: Fri Jul 25, 2014 3:23 pm
Hey guys, Id like some different opinions on this.
After looking at a few of these heads I have noticed on both ends the casting for the water flow were never cleaned out very well.
I dont know if this applies only to hydraulic heads but I have 4 of them and they are all the same ( 81 up )
Is this something typically cleaned/punched out/deburred by someone overzealous like myself?
I would think getting the water to flow as much as possible in these heads would be a good thing?
Anyone else ever run into this?
The bottom two photos show the passages to the left nearly completely shut-off by casting flack.
PostPosted: Fri Jul 25, 2014 5:08 pm
Car Model: 64 Valiant
That is a typical casting issue of all auto brands not just Chrysler. I think you keep expecting to find Ferrari type craftsmanship in a vehicle that probably didn't cost much over $3000 new, and your just not going to find it. :oops:
Where the bowls have been enlarged from the valve job, you will need to clean that up and blend with a die grinder and smooth up with a cartridge roll abrasive.
PostPosted: Fri Jul 25, 2014 7:25 pm
It can't hurt to clean that flash out of the water passages, and might help. It will make you feel better.
Sam
PostPosted: Fri Jul 25, 2014 11:59 pm
Ok thanks guys, its better to ask before I cut rather than after and make a mistake.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 15 guests
