It is currently Tue May 19, 2026 3:45 am
PostPosted: Sun Aug 03, 2014 5:05 am
Unless I am mistaken the only way to tell what year slant engines I have is to read the numbers located underneath the head directly behind the alternator area.
If that is true than what do these numbers on the drivers side of the block signify? Image
This photo was taken from an engine that is in a 1983 truck so I thought that maybe these could be good/reliable casting dates.
The Jasper recon engine that is in my 73 shows an 83 as well though so thats why I am confused.
PostPosted: Sun Aug 03, 2014 7:38 am
numbers you ext to need are stamped into top of block behind alt....next to head
PostPosted: Sun Aug 03, 2014 8:36 am
He knows that, he even started his post with acknowledgement to that info, he's asking what the casting numbers mean.
PostPosted: Sun Aug 03, 2014 10:37 am
Can you confirm that these numbers Image
underneath the head are the numbers everyone speaks of when they mention behind the alternator.
Seems stupid to stamp identification numbers there.
Not even too sure what to do with these numbers,
4 ( what is that for )
225 ( ok cubic inch )
But the what is the T ( my guess would mean T is Truck, thats the way it was done in the old days )
Then an 8 ( no clue )
And finally a 1 ( no clue )
PostPosted: Sun Aug 03, 2014 10:42 am
Also I have confirmed that the numbers cast into the block are a casting date.
I ran across a 64 this A.M that had 64 cast clearly into its side same place as all the others.
My 86 is cast with an 85 ( close enough for how I know they operate ) and I have others that are cast spot on with corresponding casting dates to vehicle year of manufacture.
PostPosted: Sun Aug 03, 2014 5:31 pm
4: 1984 model year
225: Cubic inch displacement
T: Trenton engine plant
8 1: August 1, 1983 engine build date
PostPosted: Mon Aug 04, 2014 2:16 am
4: 1984 model year
Users browsing this forum: No registered users and 26 guests
