| Can anyone tell me what these numbers are for https://slantsix.org/forum/viewtopic.php?t=55905 |
| Author: | hantayo13 [ Sun Aug 03, 2014 7:38 am ] |
numbers you ext to need are stamped into top of block behind alt....next to head |
| Author: | 63Valiant [ Sun Aug 03, 2014 8:36 am ] |
Quote: numbers you ext to need are stamped into top of block behind alt....next to head
He knows that, he even started his post with acknowledgement to that info, he's asking what the casting numbers mean.
| Author: | 1930 [ Sun Aug 03, 2014 10:42 am ] |
Quote: Quote: numbers you ext to need are stamped into top of block behind alt....next to head
He knows that, he even started his post with acknowledgement to that info, he's asking what the casting numbers mean.I ran across a 64 this A.M that had 64 cast clearly into its side same place as all the others. My 86 is cast with an 85 ( close enough for how I know they operate ) and I have others that are cast spot on with corresponding casting dates to vehicle year of manufacture. |
| Author: | SlantSixDan [ Sun Aug 03, 2014 5:31 pm ] |
4: 1984 model year 225: Cubic inch displacement T: Trenton engine plant 8 1: August 1, 1983 engine build date |
| Author: | 1930 [ Mon Aug 04, 2014 2:16 am ] |
Quote: 4: 1984 model year
Thanks
