It is currently Tue Dec 30, 2025 12:55 am
 Post subject: easiest head removal?
PostPosted: Tue Aug 12, 2014 6:56 pm
76 d 100. removed carb and noticed had a screw missing so i replaced it .fear that screw may have fell down the manifold when i picked up carb.i started the truck and heard a ping. i had 2 damaged plugs on inspection. am wonderimg what is the least amount i have to take off head before i can remove the head to see if i can find the screw? thanks in advance
PostPosted: Thu Aug 14, 2014 1:15 pm
Unless you have way more time than money, I'd be looking at getting an inexpensive videoscope & look into the cylinders via the spark plug holes. One model is the Autel MV208- is has pretty good video images & can save to a mSD card (also has a 90* mirror & a tiny magnet attachments). Prices range $100-150.
Otherwise; drain coolant, disconnect: exhaust pipe, throttle cable, trans kickdown, carb fuel & vac lines/hoses, ignition wires, heater/radiator hoses (including bypass), temp gauge & choke wiring, alternator & mounting bracket (if needed), oil dipstick tube (if needed), A/C compressor (or air-smog pump) & brackets- if needed, manifold to engine brace- if present, valve cover, rocker arm shaft w/ pushrods, lastly headbolts. Bolt a chain to 2 holes on head between manifolds & valve cover, then pick the whole mess up with an engine hoist.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Aug 14, 2014 2:02 pm
How would one screw harm two plugs? :?: If it got into one cylinder and damaged that plug I can see that, but how would it get into another cylinder?
What size was it? It is possible if it was a small screw that it passed through and is gone. More likely not!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
