It is currently Thu Aug 27, 2026 1:03 am
PostPosted: Tue Aug 19, 2014 6:19 am
What is the material that was used in my engine compartment to prevent road grime from coming up through the wheel wells?
During my front suspension rebuild all of the material disintegrated and now needs to be replaced. I just dont have a clue what to use.
Does not have to be an exact replacement, just something that will cover up those opening.
Thanks
1975 Dodge D100 Utiline
Slant 6, Super Six, Weber 38, 727
Repair work in progress. :)
PostPosted: Wed Aug 20, 2014 7:54 pm
it was rubber about 1/4 inch thick held to inner fender with wire clips
PostPosted: Sun Aug 24, 2014 3:38 pm
After 1978 or so, Mopar put plastic front inner fender linings in all their cars. You can find something at the Junk Yard that will protect all the metal, including the fenders. I got mine from a 79 New Yorker parts car I had for awhile.
I fastened them in with nylon screws, but you could use the standard plastic push-in connectors used these days.
Sam
PostPosted: Mon Aug 25, 2014 4:10 am
called mastic I believe.
Brian
63 Plymouth Valiant Wagon
Users browsing this forum: Bing [Bot] and 14 guests
