It is currently Sat May 09, 2026 2:42 pm
 Post subject: uneven rear end
PostPosted: Sat Aug 23, 2014 6:20 pm
I replaced my old 7.25 for an 8.75 and ESPO leaf springs at the same time. The ride is a bit stiff, but it's much more stable back there. The height is uneven, one side is a bit higher than the other, about 3/4 inch. ESPO says they take great measures to make sure their springs are matched.
Anybody have this issue? Best way to even it out? Do I put a heavy weight in the trunk on the higher side for awhile or what?
thanks all,
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sat Aug 23, 2014 6:42 pm
Relocate the battery to the high side? 8)
PostPosted: Sat Aug 23, 2014 7:16 pm
Maybe when you set in the car it is even? :lol: Which side is higher?
PostPosted: Sat Aug 23, 2014 7:24 pm
Did you tighten the bushing bolts when the car was jacked up?
 Post subject: bushing bolts
PostPosted: Sat Aug 23, 2014 10:38 pm
I didn't install the springs, but do you mean to suggest the bushing bolts are too tight, I don't think that's the issue.
PostPosted: Sat Aug 23, 2014 11:44 pm
You tighten rubber bushings when the vehicle is on the ground.
Otherwise they act like a torsion bar (raising the vehicle a little) until they rip apart internally.
