Slant Six Forum https://slantsix.org/forum/ |
cam replacement time https://slantsix.org/forum/viewtopic.php?t=56116 |
Author: | barryc315 [ Thu Sep 04, 2014 6:44 am ] |
Post subject: | cam replacement time |
I was wondering if anyone knew a flat rate time to replace a cam? |
Author: | slantzilla [ Thu Sep 04, 2014 7:14 am ] |
Post subject: | |
Engine in the car or out? |
Author: | Doctor Dodge [ Thu Sep 04, 2014 7:40 am ] |
Post subject: | |
More info would be helpful because it is unusual to just replace a camshaft alone... unless you want to do it for a performance change / power improvement. Said another way... A camshaft replacement is a big job so you may want to do a full engine rebuild or replacement, if you are working with a high mileage engine. DD |
Author: | barryc315 [ Thu Sep 04, 2014 6:54 pm ] |
Post subject: | |
Thanks for the replies. The job is an in the car swap a 1976 Duster auto. I'm installing a Clifford intake and headers also recurving the distributor. |
Author: | WagonsRcool [ Fri Sep 05, 2014 10:58 am ] |
Post subject: | |
I pulled a labor time for Apen/Volare- 7.0 hours + .3 for A/C. ( you have to pull the head to get the lifters out with the 75-up peanut plugs) |
Author: | wjajr [ Fri Sep 05, 2014 1:51 pm ] |
Post subject: | |
Quote: ( you have to pull the head to get the lifters out with the 75-up peanut plugs)
Yup.
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
