It is currently Fri Nov 13, 2026 9:35 pm
 Post subject: gear oil
PostPosted: Fri Sep 12, 2014 4:31 pm
I have switched to 8.75, power lok clutch type posi, is this gear oil OK?
http://www.redlineoil.com/product.aspx?pid=44&pcid=4
A racing buddy of mine suggested this is a really good gear oil for rearend, but I wanted to know if anyone here uses it or has a recommendation for rearend oil type/brand.
thanks,
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Fri Sep 12, 2014 8:39 pm
Heavy shock proof is way overkill for a slant 6 powered vehicle. It's meant for racing not long term road use. Use their regular 75W-90 GL5.
PostPosted: Sat Sep 13, 2014 3:58 am
I would use whatever you can find that is good quality 75-90 or 80-90 gear oil (Castrol, Valvoline, Mobil...), and make sure to use an additive for the suregrip, preferably the Mopar additive. That really makes a difference in chattering and longevity of the suregrip.
 Post subject: Thanks, great...
PostPosted: Sat Sep 13, 2014 6:48 pm
Thanks for all the advice, sounds good.
b
 Post subject: royal purple
PostPosted: Wed Oct 08, 2014 1:39 pm
I went with Royal Purple (85W-140) and friction modifier. It is much quieter now, actually.
http://www.latemodelrestoration.com/ite ... fgodCC4Auw
I also installed a drain plug...
FYI,
Brian
 Post subject: added benefit...
PostPosted: Sat Oct 11, 2014 2:00 pm
my slow leak in the pinion seal is now gone! I've been driving it for a few hundred miles and I see no signs of leakage whatsoever, dry as a bone. That rearend oil that I took out did seem much less viscous than the royal purple.
FYI,
Brian
