| gear oil https://slantsix.org/forum/viewtopic.php?t=56182 |
| Author: | '67 Dart 270 [ Fri Sep 12, 2014 4:31 pm ] |
| Post subject: | gear oil |
I have switched to 8.75, power lok clutch type posi, is this gear oil OK? http://www.redlineoil.com/product.aspx?pid=44&pcid=4 A racing buddy of mine suggested this is a really good gear oil for rearend, but I wanted to know if anyone here uses it or has a recommendation for rearend oil type/brand. thanks, Brian |
| Author: | Joshie225 [ Fri Sep 12, 2014 8:39 pm ] |
Heavy shock proof is way overkill for a slant 6 powered vehicle. It's meant for racing not long term road use. Use their regular 75W-90 GL5. |
| Author: | Dart270 [ Sat Sep 13, 2014 3:58 am ] |
I would use whatever you can find that is good quality 75-90 or 80-90 gear oil (Castrol, Valvoline, Mobil...), and make sure to use an additive for the suregrip, preferably the Mopar additive. That really makes a difference in chattering and longevity of the suregrip. Lou |
| Author: | '67 Dart 270 [ Sat Sep 13, 2014 6:48 pm ] |
| Post subject: | Thanks, great... |
Thanks for all the advice, sounds good. b |
| Author: | '67 Dart 270 [ Wed Oct 08, 2014 1:39 pm ] |
| Post subject: | royal purple |
I went with Royal Purple (85W-140) and friction modifier. It is much quieter now, actually. http://www.latemodelrestoration.com/ite ... fgodCC4Auw I also installed a drain plug... FYI, Brian |
| Author: | '67 Dart 270 [ Sat Oct 11, 2014 2:00 pm ] |
| Post subject: | added benefit... |
my slow leak in the pinion seal is now gone! I've been driving it for a few hundred miles and I see no signs of leakage whatsoever, dry as a bone. That rearend oil that I took out did seem much less viscous than the royal purple. FYI, Brian |
