It is currently Tue Dec 30, 2025 10:05 pm
 Post subject: engine missing
PostPosted: Mon Sep 15, 2014 10:04 am
Hi !
For sometime the cylinder#6 is missing. I just found out this morning that when engine is cold, With the choke on, I remove the spark plug wire and it is missing. Put it back and it run fine. All other cylinder does the same.
May sound funny to write this but when the engine is hot if I unplug cylinder#6 it makes no differnence. And all other cylinders misses when I unplug spark plug wire.
I made a compression test all cylinder tested 155-160, but #6 read 170, wire are good , spark plug are good.
Anybody could help?
PostPosted: Mon Sep 15, 2014 10:57 am
Try adjusting the exhaust valve on that cylinder.
PostPosted: Sat Sep 20, 2014 5:50 am
You were right, I reajusted the valve with the engine running, and the exhaust valve was a bit lousse, witch cause that cylindre to have higher compression and to run ok when cold.
Users browsing this forum: Google [Bot] and 6 guests
