It is currently Sun Nov 15, 2026 5:54 pm
 Post subject: green bearings
PostPosted: Tue Sep 16, 2014 4:30 pm
I know that one can use the Green Bearings for changing axles from SBP to LBP and when doing so, one must change to 10 x 2.5" brake setup.
But, can one use green bearings with SBP axles with 10 x 1.75" brakes?
thanks all,
brian
https://tinyurl.com/yynpj4v2
PostPosted: Tue Sep 16, 2014 5:12 pm
Yes
 Post subject: Thanks!
PostPosted: Thu Sep 18, 2014 3:30 pm
I also popped that question to Doctordiff and got the same answer.
Can't wait to drive my dart again....
b
PostPosted: Thu Sep 18, 2014 3:33 pm
Just make sure they are the two piece type where the outer flange the bolts go through is a separate piece. It sits on the clip when installed.
PostPosted: Thu Sep 18, 2014 5:13 pm
Yup, running them on my 8 3/4" Suregrip.
PostPosted: Fri Sep 19, 2014 12:16 am
IIRC, you also have to pull the spacer buttons out of the diff or you run the risk of burning your green bearings up.
