green bearings
https://slantsix.org/forum/viewtopic.php?t=56211
Author:  '67 Dart 270 [ Tue Sep 16, 2014 4:30 pm ]
Post subject:  green bearings
I know that one can use the Green Bearings for changing axles from SBP to LBP and when doing so, one must change to 10 x 2.5" brake setup.
But, can one use green bearings with SBP axles with 10 x 1.75" brakes?
thanks all,
brian
Author:  Charrlie_S [ Tue Sep 16, 2014 5:12 pm ]
Yes
Author:  '67 Dart 270 [ Thu Sep 18, 2014 3:30 pm ]
Post subject:  Thanks!
I also popped that question to Doctordiff and got the same answer.
Can't wait to drive my dart again....
b
Author:  Pierre [ Thu Sep 18, 2014 3:33 pm ]
Just make sure they are the two piece type where the outer flange the bolts go through is a separate piece. It sits on the clip when installed.
Author:  wjajr [ Thu Sep 18, 2014 5:13 pm ]
Yup, running them on my 8 3/4" Suregrip.
Author:  slantzilla [ Fri Sep 19, 2014 12:16 am ]
IIRC, you also have to pull the spacer buttons out of the diff or you run the risk of burning your green bearings up.
